JOIN not Working In Script
Message 1 of 12
I'm making a script to join everything in a drawing, save, then move on to the next.
My script is as follows:
OPENFILE <1st drawing>
JOIN
ALL
SAVE
OPENFILE <next drawing>
This works perfect when it is typed out. When it is saved as a .scr file and ran  the process does not work.
It seems like a very simple script, and I cannot get around why it is not working.
When I physically type "JOIN" I have the choice of source or multiple objects (I reply with "ALL"):
When it is scripted there is only the choice of "source object" and "ALL" fails (as seen below):
I have also tried:
_ai_selall
JOIN
This again works great when typed manually, but not when scripted.
Replies (11)
Message 2 of 12
ВeekeeCZ
So do what you asked...
join
last
all
or try LISP to help...
(initcommandversion)
join
all
Message 3 of 12
I have no experience with LISP, so I'm trying to stick with what I know with .scr files.
I tried running what you suggested. Similar to what I've already been experiencing, the commands work well when manually typed, but when scripted it fails. No matter what I seem to do, the selection of objects after JOIN is flawed when scripted it seems. Here's the script I wrote:
FILEOPEN
<filename>
JOIN
last
all
What my command line says:
Command: JOIN
Select source object: last
Line, open polyline, arc, elliptical arc, or open spline expected.  Select a supported object: all
*Invalid selection*
Expects a point or Last
Message 4 of 12
ВeekeeCZ
That's a problem.
You need to supply the JOIN command (in it's "script/lisp" version) with some single linework entity first (line, arc, polyline), then with a group of entities (all). But how would you get some single entity automatically? The most simple way was to select the last object in the database. Unfortunately, it's not a linework type of entity in you case. I don't know of any different way using just a SCRIPT.
So you can either use the PEDIT command with its JOIN option, or go with LISP which gives you much more opportunities to solve the issue.
Message 5 of 12
Just a wild guess, but what happens if you try selecting all first, then join?
Message 6 of 12
Any resource in specific you would suggest to learn LISP?
Message 7 of 12
Exact same issue unfortunately 😓
Message 8 of 12
sthompson1021
Try using this with PEDIT command. It worked for me on a test dwg.
pedit
m
all
join
save
Y
close
Message 9 of 12
ВeekeeCZ
Lots of people consider THIS  site as good starting point.
I tough myself from a book (not eng).
If you decide to use the PEDIT, remember that there is PEDITACCEPT sysvar.
Message 10 of 12
I've tried PEDIT and it doesn't seem to work for my application. I work at an underground mining operation and the drawings I'm trying to join are underground tunnel face surveys. The drawing is 3D in nature with a bunch of broken up polylines generated from our mining software. I'm trying to join as many of the touching polylines to compress the drawing as much as possible. I've attached a sample drawing if you can get it to work.
Message 11 of 12
ВeekeeCZ
Once again, this works.
join
all
Message 12 of 12
pendean
Community Legend
Community Legend
