Message 1 of 20
08:48 AM
Hi, I haven't used the flatten command in a long time and needed it the other day.
Maybe this is something new with it, but it is forcing all blocks to the current layer and adding a numbered "flat" suffix at the end.
This is not good. The only way to get the blocks back to their original layer is to explode it.
And renaming the block is even worse.
Is there any way around this. I ended up using the "change" command instead.
Rick
