Issues with broken links to xrefs
leekennewell
leekennewell
I need to stop broken links to a "parent" drawing after its xref has been moved to another folder location.
To create my component drawings, the detailed views come from the assembly drawing they feature in (so in the component drawing i freeze all layers within the xref apart from the layer the component i want to detail is on).  My problem is when drawings are approved and released within the company, all the component drawings are moved to another folder location, but the xref doesn't follow to the same folder.  Consequently, none of the views in the component drawings display because the xref is no longer in the same folder.  I have experimented with the different xref path types but no joy.
Other bits of (possibly) useful information:  Changing my company's process, i.e have all the files moved together whilst in the same folder, is not an option.  I work on a server and use i AutoCAD 2024.
paullimapa
No perfect solution when you move the component xref (child) dwgs to a new location.
The host (parent) dwgs will not magically know where their children have all gone regardless of what paths (absolute, relative or none) you used as you've experienced.
Now a possible solution (assuming there are no other dwgs that end up staying in that folder where the child dwgs were stored and all the children are all moved together to a new folder location) you can run the Reference Manager tool which comes with AutoCAD as a separate app (found in the AutoCAD 2024 program folder), select the folder where all the parent dwgs are and then do a search & replace for the old folder name with the new folder name for the child dwgs. The Reference Manager will automatically without opening any dwgs process this command.
Paul Li
IT Specialist
@The Office
TomBeauford
You didn't give much of a description of the before and after folder locations or how they're referenced to each other.
Commonly projects have a main folder with other drawings, images & documentation in subfolders. Then the entire project with it's folder structure is moved. In this case as long as relative paths were used from the start they wouldn't require any modification.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
RSomppi
That is the expected behavior. Whoever decided to move the files hasn't taken this into consideration.
Is copying the file (instead of moving) acceptable?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
