Issue with line/polyline lag
Message 1 of 8
I've recently been experiencing a bad lag in AutoCAD 2020 when trying to draw lines or polylines (as well as dimension between two point, or any other 2D command).  I am running a MS Surface Pro 6 with Win 10.
Everything has been fine to date, but suddenly this issue arose. Whenever I use these commands, the program seems to lag, or jitter between points, making it impossible to work effectively. However if i am drawing a square or anything else of the like, it runs absolutely fine....
As a bit of background, this issue occured several months ago as well and I contacted MS as i assumed it was a hardware issue, however they could never fix the problem, nor could I by deleting the reinstalling software. They ended up replacing my Surface Pro and everything started fine... but now the issue is back...
Replies (7)
Message 2 of 8
Alfred.NESWADBA
Please show us two screenshots, one from command _ABOUT and the second from command _GRAPHICSCONFIG.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
imadHabash
if you turn off Dynamic Input [ F12 ] , any changes ?
Imad Habash
Message 4 of 8
pendean
Community Legend
Community Legend
Is it only slow when you are not plugged in (power)?
Message 5 of 8
Thank you!
I'm just a dumb engineer so don't know much about CAD, but this fixed it immediately...
Hilarious MS gave me a brand new computer for it though.
Cheers
Message 6 of 8
thank you so much. been going on the internet for an hour and turns out I only need to click f12. it solves the problem immediately
Message 7 of 8
fsajjad473
Observer
Observer
issue solved but now i can not see angles of lines and other things shown on dynamic input
Message 8 of 8
RedbrooksSpecialistDesign
Community Visitor
Community Visitor
Thank you Imad, that was driving me insane. F12 perfect solution. B
