Issue with hatch when use a background in autocad 2015
Message 1 of 14
If I made a HATCH with lines and I apply a background color ...  this HATCH is showing complete black in the layout, the lines is not show and the background can see ... only a black color
Replies (13)
Message 2 of 14
filipefrancisco
Change the scale of the hatch
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
Message 3 of 14
h_s_walker
What is the colour of the layer the hatch is on?
What is the background colour you are using for the hatch?
Howard Walker
Left Handed and Proud
Message 4 of 14
pendean
Community Legend
Community Legend
DRAWORDER perhaps is what you need to do, bring the lines to the front.
Message 5 of 14
Hello, is not a problem of scale... we do that .. and the result is the same
Thank you
Message 6 of 14
Is not a draw order becoause is only one hatch ... hatch in lines with background.
Thank you
Message 7 of 14
jggerth
Is it displaying as solid black on screen?  or on hardcopy?
If the former, are you using Lineweights?  and is the lineweght of the hatch to heavy?
Message 8 of 14
For better ilustration... I insert 3 images
First image is autocad 2014, in the layout mode with plot style applied ... no problem is how we want to see
Secon image is autocad 2015, in the layout mode without plot style applied
Third image is autocad 2015, in the layout mode with plot style applied ... the hatch is totaly black.
fourth image ... properties of the hatch
Is the same file... opened in both vertions
Sorry for my english ... I am in Colombiahatch-no-issue-2014.JPGhatch-no-plotstyle-2015.JPGhatch-with-plotstyle-2015.JPGhatch-properties-no-issue-2014.JPG
Message 9 of 14
Hi... solid black is on screen, in hard copy is good... but you can see my other post with images to ilustrate the problem... this issue is only in 2015 becouse the same file open in 2014 don't have the same issue
Message 10 of 14
pendean
Community Legend
Community Legend
AutoCAD graphics engine is different in 2015: nothing like 2014. Your video card is not handling it well. Turn off LINESMOOTHING in 2015 (it's not in 2014) and see if your problem goes away.
ANSI32 hatch does not look solid here in 2015 with your posted settings.
Message 11 of 14
Where is the LINESMOOTHING ?
Is a system variable ?
Message 12 of 14
pendean
Community Legend
Community Legend
Type it at the comandline: look it up in HELP in 2015 for an explanation.
Hope that fix works for you.
Message 13 of 14
delete the old hatch abd try to use hatch with a pick point option
Message 14 of 14
leigh.bakerXGUPW
Community Visitor
Community Visitor
Hi there, digging up an old thread here but having the same issues in version 2019 and seem to have sorted a solution.
The key is to create a layer that plots in colour for the hatch, (using .stb plot styles set the layer plot style to 'normal') and use a dark colour (250) for the layer to represent the black lines of the hatch pattern.
Create the hatch on this layer and add the background colour to the hatch (I chose a shade that also plots in colour) and now it displays the same in paper space and when plotted to hard copy or PDF.
I've added 3 images, first being the layer manager settings, second the hatching shown in model space and lastly, shown in paper space.
Hope this helps!
