Issue: LTSCALE in paper space
DisturbedCorner
DisturbedCorner
I have a number of paper space tabs using a variety of scales. The current workflow is, go into Tab 1, set LTSCALE to 80 make edits and print. Go into Tab 2, set LTSCALE to 40, make edits and print, etc...
Similar to how in a paper space tab, if you activate model space inside of that paper space and set a custom UCS, it only affects that paper space tab, and not even the model space itself, I would imaging setting LTSCALE to something would only affect that paper space tab as well, but this is global.
I imagine this problem only applies to myself, what do other people do to get this effect?
Note: we use the Page Setup Manager to set a 1:xx scale and change the view port size to something large to take up the paper space in order to measure on the screen the same distances as in model space, but at the same time be able to print an accurate scale on paper. I know most people use 1:1 in Page Setup Manager and leave the viewport size about the size of the paper they want to use which I have done a little of as well. While I would prefer to keep our Page Setup Manager method, sometimes in order for LTSCALE to cooperate, it would be worth while using 1:1 so any suggestions will help.
Thank you.
cadffm
check out PSLTSCALE [F1]
It uses the viewport scale additional to LTSCALE
test it with a layout what is set up to plot in plotscale 1:1 sample too.
Sebastian
TomBeauford
Do you have "Scale lineweights" checked when plotting your 1:xx scale?
You shouldn't have to modify the LTSCALE.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
dbroad
Read about these variables:
CELTSCALE
LTSCALE
MSLTSCALE
PSLTSCALE
I suspect that if you set MSLTSCALE to 1 and PSLTSCALE to 1 and if you set your annotation scale in the model tab and in each paperspace viewport, your problems will be solved. You won't need to change LTSCALE.  For the few items that need tweaking, select them and use the properties palette to adjust the ltscale.  LTSCALE should be set between 0.5 and 1.0 depending on your office needs, usually 1.0 and otherwise left alone.  CELTSCALE should be left at 1.0.  Be sure to lock the scale for your paper viewports.
Architect, Registered NC, VA, SC, & GA.
paullimapa
Share a sample dwg so we can take a look how it’s composed
Paul Li
IT Specialist
@The Office
