Isometric Piping
Isometric Piping
Message 1 of 10
Isometric Piping
Hey everyone I'm new to the Autocad community. I was tasked with creating Isometric Pipe drawings with the new AutoCad 2017. My question is that how do I insert pipe symbols such as valves, welds, flanges etc. is there a file or add on I have to download?
Replies (9)
Message 2 of 10
imadHabash
Hi and Welcome to AutoDesk Forum,
you can use some existing samples by Ctrl+3 shortcut.and if you have your own library you can use INSERT  command to bring what you need and you can also use copyclip Ctrl+c  and Ctrl+v to copy from file to another.
Good Luck...
Imad Habash
Message 3 of 10
TheCADnoob
For simply inserting blocks as @imadHabash insert works great.
I would check to see if your company has a standard that they use (or are supposed to use). If they do they likely have blocks for the associated standard.
If you are starting this from ground up you should look into creating templates which will have everything in you drawing ready to go. This example is for electrical but the ideas are the same. A template will have all you blocks already loaded in it so you dont have to dig to far to load them.  :https://knowledge.autodesk.com/support/autocad-electrical/learn-explore/caas/CloudHelp/cloudhelp/201...
I find it useful when dealing with ISO to make sure i have the polar tracking set to 30.
If you are having to create the pipe symbols i might start by downloading something like this : http://www.cadforum.cz/catalog_en/block.asp?blk=3932 and create blocks out of those pieces. (or simple copy and paste, but id recommend creating blocks)
CADnoob
Message 4 of 10
GrantsPirate
I would draw those in 3D rather than iso.  In 3D all existing symbols work without any modification, dimensioning is easier, if you need to show the pipe from a different angle it is very easy to do.  In an Iso, if a different viewing angle is needed you must redraw from scratch.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 5 of 10
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
I too suggest that you do this work in true 3D. It is easy to show an Isometric representation once you have things modeled but it becomes even easier to change views if it is drawn in 3D. As far as INSERT goes, there are many ways to do this:
  • Drag-and-drop
  • Insert
  • -Insert
  • DesignCenter
Please let me know if you need additional information on any of these commands or on the 3D modeling portion of my suggestion. You might want to check out the ViewBase command for creating views.
John Vellek
Message 6 of 10
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 7 of 10
fc
Observer
Observer
Hi John, I don’t see a reply from @@Anonymous but, for me, would you explaining the 3D modeling of your suggestion. I also am struggling to create isometric piping drawings. Thank you.
Message 8 of 10
imadHabash
@fc
Would you start a new post in this forum ( press Start a Topic button in the main page ). write more details please and describe why you're struggling to create isometric piping drawings. This way, you will ensure broader participation to help provide the most suitable solutions for you.
Waiting from you...
Imad Habash
Message 9 of 10
pendean
Community Legend
Community Legend
"anonymous" is a user that is no longer active in the forums and has been deactivated, and "john" no longer works for Autodesk.
As others have suggested, you're best served starting your own post from scratch in 2025.
Message 10 of 10
TheCADnoob
in addition to the other comments check out Plant 3D
https://www.autodesk.com/products/autocad/included-toolsets/autocad-plant-3d
CADnoob
