Message 1 of 25
ISO autoadjust of some sort so I can join polylines or splines w tiny gaps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So sometimes at work we get client DWG files that were computer generated and need to be cleaned up before use. Not uncommonly, instead of a nice fluid spline or polyline, the drawings are made up of a ton of tiny segments that don't quite meet each other so the join command doesn't work.
It's a pain to try to modify the drawings with hundreds of tiny lines and it takes forever to join them all.
Is there any option or command or lsp program that would autoadjust the positioning of the line/spline segments so that they meet end to end so that the join command will work?
(the gap between them is so small it wouldn't make a difference which segment got moved in terms of the drawing appearance)
Thanks 🙂
