Is there an easy and quick way to print those?
Hi guys and thanks in advance. I have a project that contains over 800 hundred report that I want to print as shown in the attached image each report is define by the rectangle shown. My question is there a quick and easy way to print them all at once rather than do the printing for them 1 report at a time?
Thanks for the help in advance.
rkmcswain
If you had a layout setup for each one, it would be a simple matter of running PUBLISH or using SSM to print them all unattended. I presume that screenshot is of model space. If you have a named view for each print area, it could be scripted. If the coordinates of each rectangle were known, it could be scripted also.
Let's say that I can get the coordination of each rectangle how do you do the scripting?
