Is there a way to get model space point coordinates to a paperspace table?
AutoMarcus
AutoMarcus
hi all, i posted a question here in customisation
I am trying to pull point coordinates from model space and put them on a table
i had another idea, to use fields.
is there a way use a field in paperspace that identifies a point in model space through a viewport?
cadffm
Thru a viewport not, the object has nothing to do with your viewport,
but sure you can read object data by using a field.
it doesn't matter where the object is and where the field.
How to
Create the table in modelspace, clip&paste to layout don't work?
Then:
1. Copy fieldcodes step by step
2. A tool to copy fields can also help.
Bye
Sebastian
AutoMarcus
cheers
I am trying to make a tool or block for my team who do this regularly
At the moment the team are ID'ing points and copying them to an excel table, then converting them from mm to meters
then copying and pasting the text geo coordinates to a table in paperspace.
trying to think of a better way
cadffm
And DATAEXTRACT is not an option?
Sebastian
AutoMarcus
edited
hi @cadffm  i don't wish to extract the data from cad to an excel spreadsheet,
id like to get the 5 points x and y (divide them by 1000), that are in model space, and put them on a table in paper space
