Is there a way to extract XYZ coordinates from only xref blocks?
I'm working on a big project and we're having some trouble with xrefs ending up at different insertion Points (probably due to the original drawing having a faulty BASE)
Now I'd like to do a data extraction reporting the XYZ coordinates of just the Xrefs of the files
(so I can easily track the faulty insertions)
I've gotten so far that I can extract the correct data, but is there any fast and reliable way to select just the xrefs and not have to deselect other blocks in the drawing so the process can be automated more easily?
Ideally I'd create something like:
data extraction > select all xrefs in selected drawings > extract XYZ coordinates > output to excel file
Kent1Cooper
@Anonymous wrote:
.... is there any fast and reliable way to select just the xrefs and not have to deselect other blocks in the drawing so the process can be automated more easily?
One way is to check whether the Block table entry for each INSERT object contains a path  [i.e. an (assoc 1) entry other than an empty "" string], which only Xrefs do.  This reports their "Block" names to the command line, but you can adjust it to put their entity names into a list or a selection set, or send each one's information out to an external file as it goes, or whatever else makes the most sense for the data extraction.
(setq blkss (ssget "_X" '((0 . "INSERT")))); get all INSERT objects
(repeat (setq n (sslength blkss))
  (if
    (/= ; looking for those without a path string
      (cdr
        (assoc 1 ; path, if there is one
          (entget
            (tblobjname "block"
              (setq xrname (cdr (assoc 2 (entget (ssname blkss (setq n (1- n))))))); name
            ); tblobjname
          ); entget
        ); assoc
      ); cdr
      "" ; empty string [means ordinary Block]
    ); /= ; if it isn't  empty, it's an Xref, so:
    (prompt (strcat "\n" xrname))
  ); if
); repeat
Another way is to check whether the (assoc 70) value contains the 4 or 8 "bit" that indicate an attached or overlaid Xref:
  (if
    (/= ; looking for those not  containing those bits
      (logand
        (cdr
          (assoc 70
            (entget (tblobjname "block" (setq xrname (cdr (assoc 2 (entget (ssname blkss (setq n (1- n)))))))))
          ); assoc
        ); cdr
        12 ; = 4 + 8
      ); logand
      0 ; if it's an Xref, this will be 4 or 8 or 12
    ); /= so if that's the case [i.e. it's not zero]:
  ); if
); repeat
Kent Cooper, AIA
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 When you set up the dataextraction, it allows you to select which drawing(s) to utilize. Simply select the Xref files and not the host file and I think that should give you the results you want.
John Vellek
Thanks!
However, I'm specifically interested in the xref insertion points (perhaps I wasn't clear on this point) and so I'm looking for a way to extract this data from host files in a sleek manner, preferably without having to bother with the other blocks. Of course, being new to this side of CAD:ing I might have missed something in your description.
@john.vellek wrote:
Hi @Anonymous,
Kent1Cooper
@Anonymous wrote:
…. I'm specifically interested in the xref insertion points (perhaps I wasn't clear on this point) and so I'm looking for a way to extract this data from host files in a sleek manner, preferably without having to bother with the other blocks. ….
You could change this line in the first routine in Message 2:
to this, to keep the entity data list for use later:
              (setq xrname (cdr (assoc 2 (setq xrdata (entget (ssname blkss (setq n (1- n)))))))); name
and then at the end, pull the insertion point from that, by replacing this line:
to something involving:
    (cdr (assoc 10 xrdata))
which is the insertion point, as a list of XYZ coordinates.  What you surround that with depends on exactly what kind of file you want to put it in [involving a (write-line) function and a conversion from numbers to text], or what kind of Text you want to draw it into the drawing with, or ….
Kent Cooper, AIA
