Hi @Anonymous
Sorry, there is no variable such as that. May I know why you are trying to scale the length of the line being drawn? If you want to draw a line at half the length then you can divide the length by 2 when you input the distance. For example, if you want to draw a line that is half the distance of say 25 then, you can type in the command "LINE" and then select the start point and input the distance as "25/2". Now the length of the line will be 12.5 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
