is there a limit of the number of sheets for a dst file?
hjh2
hjh2
Community Visitor
Community Visitor
I'm using a sheet set which has about 350 sheets already.
and ive tried to add a sheet on it but failed.
and found out on this forum that a problem could happen if a dst file has more than 300 sheets.
I wanna know if theres a limit for the number of sheets per dst file.
Valentin_CAD
@hjh2 ,
I'm not aware of any limitation to a dst, but here are some suggestions.
Another suggestion could be to use a shorter path or shorter folder names within the path.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
JTBWorld
No limit, do you see any error?
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
