Is it possible to segment a line into evenly spaced point data?
201821253
Observer Observer
201821253
Observer
Observer
I am trying to divide the following line into point data with a specified interval. And I want to get the coordinate values ​​of each points.
I tried 'xplode', 'break' command. But it isn't what I need.
Pointdump
Hi @201821253,
Did you try Command DIVIDE? Then you can use Data Extraction to get coordinates of the points.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
tramber
1) Use better MEASURE to specify a distance along the polyline and draw points (nodes) or insert blocks (it is an option) and then you can extract those datas...
2) Second option, if i understand that you just want to extract coordinates of a polyline, this is a fast made lisp :
(defun c:expts(/ profile result)
  (cond(
	(setq profile(entsel "\nSelectionnez la polyligne\n"))
	(setq result(mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget(car profile)))))
	(foreach p result
	  (princ(strcat(rtos(car p)2 2)"," (rtos(cadr p)2 2)"\n")))))
  (princ)
Load it, run EXPTS and you will get the coordinates...
1) or 2) ?
Zlatislav.atanasov
Hi @201821253
There is a great LISP that does just what you need. It Splits Polylines into equal segments you can check it out here: How to Split Polyline into a number of Segments or at Intervals?
My personal blog - AutoCAD and AutoCAD Civil 3D hidden Secrets and great tips in one place -
https://skillamplifier.com/
Amplify your skills to a new level!
Kent1Cooper
Do you want the line [or arc, or polyline, or circle, or...] actually broken into pieces at that interval, or do you just want the coordinates at locations along it at that interval?  If the former, I have a routine to do that by specifying the number of equal-length pieces you want it broken into, which could be edited to use a specified interval instead.  If the latter, in what form?  An AutoLisp list of point-coordinate lists?  Text in the drawing somehow?  An external file of some kind?  Etc.
Kent Cooper, AIA
