I have an application that should work with a NURBS model exported from AutoCAD. Is it possible to export a surface with negative weights?
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I have little experience working with NURB surfaces but my understanding that it is not a best practice to work with 0 or negative weights. Do you have a sample that I can examine? I tried creating a simple planar surface and then used Convert to NURBS. Then I elected to edit one of the CV's and dragged it in a negative direction. I am not sure if this is what you are looking to do.
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Hi @Anonymous,
Can you give more specifics on what formats your other program can accept? I would like to test one of your NURBS models if you can provide it on a post.
@john.vellek FYI, the OP also posted this question on the 3ds Max forum. You can get a little more insight into his goals there.
AutoCAD's splinedit command for weights states "Value must be positive and nonzero."
Lee
I suppose another detail worth mentioning is that the "-1" CP weight (displayed more often than not) in the Properties Pallete is just an AutoCAD convention to indicate that all of the CPs have a weight of 1. If even just one other CP has a weight other than 1 (always Positive), then none of the weights will have the Negative sign.
