Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Is dedicated graphics needed for AutoCad 2020 if Im only doing 2d work ?
Hi everyone, I hope everyone is staying safe, this is my first post sorry If my English is not at its best
So is as simple as what the title says, I'm thinking about building a new computer, mostly for 2D drawings and sketching, so I went to a place and the guy told me I should get an I7 9700k  (which I think is ok) but he also included an ASUS Gt 1030 2GB, which I'm kind of sceptical about it, because I know it's not a great graphics card, kind of outdated I think, and I know that is not certified by Autodesk to work with AutoCAD. I´ve seen in many forums that people only talk about 3D AutoCad and renders and so on, which gets a benefit from a discrete graphics card such as 1030. But if I'm only doing 2D work, is that the case? If not, would it be fine If I just go with the integrated graphics, the I7 9700K I'm considering comes with intel HD 630 graphics I think
If anyone wonders, the rest of the pc is as it goes:
Singlestick of 8gb 2666MHZ
1TB Western Digital Blue 3.5 SATA 7200 64MB
SSD M.2 240 GB KINGSTON A400
Asus prime B365M-A M-ATX
Intel Core I7 9700k
GAMEMAX 500WTS 80PLUS power supply
Thanks for reading me
ennujozlagam
i think there will be no issue on that if you are just doing 2D work, you can go to GRAPHICSCONFIG command and switch off. thanks
imadHabash
Hi and Welcome to AutoCAD Forum,
you can follow here this AKN article that provides the system requirements for AutoCAD products. >> Click <<
Imad Habash
vinodkl
Hi @Anonymous
You can work on 2D using the integrated graphics. There is no requirement of buying the graphic card if you are not working on 3D. But I would suggest increasing the RAM to 16Gb instead of 8gb.
 I have earlier worked on 2D( drawing size of more than 60Mb)and basic 3D on AutoCAD using the integrated graphic, i5 processor, and 16 gb RAM. Since you have the SSD as well you can use that for AutoCAD for better performance🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
