Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Here is a link to the AutoCAD 2018 system requirements for others that might join this thread. I suggest though that if you are provisioning new computers you should look to the 2019 specs as they (IMHO) are much more realistic for Windows 10 environments and running AutoCAD with any kind of complex data such as 3D, rendering, point clouds, etc.
Without knowing more about the hardware you are considering, it is hard to determine whether the on-board graphics will be sufficient. In most cases that I see, Hardware Acceleration is not capable which means 3D capability is going to be hindered.
John Vellek
