AutoCAD Forum
Invisible, unselectable viewport (all layers on)
3 REPLIES 3
2456 Views, 3 Replies
AutoCAD Map 2011
Driving me crazy. One viewport. Unable to select grips/polyline/viewport so I can delete, move alter in any way.
All layers on, purged, audited, regen all. Read a few other similar queries, but so far nothing has helped. Any advice?
3 REPLIES 3
Alfred.NESWADBA
what happens when you are in layerspace of that layout and press <CTRL><A> (for "select all").
Or start command _QSELECT and use viewport/all as options?
Also you can start command _AUDIT to repair the drawings database.
And last but not least, if you copy the layout, do you then get the viewport selectable?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Very strange. I've just CTRL-A and viewport was still invisible. Pressed ESC to unselect all, and the viewport layer appears (under the viewport layer it was on, and what all the other viewports were on). I can now delete it.
This is after an hour or so of trying to figure this out. I still don't know what's going on with it. It was on the same layer as the other vports but was invisible and unselectable. Weird.
Thanks for the reply. I did try all of this beforehand. For some reason it's decided to appear!?
doni49
http://www.cadtutor.net/forum/showthread.php?47036-Invisible-viewport
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Autodesk Customer Advisory Groups
