AutoCAD Forum
Invisible Top Tool Bar
3 REPLIES 3
427 Views, 3 Replies
I installed the Autocad 2014 Student Version. Top toolbar (save,undo,redo buttons & etc) is invisible. But when clicking randomly in the white space there those buttons do its functions but invisible. Pls help to fix this issue
3 REPLIES 3
imadHabash
this is Quick Access Toolbar and i'm afraid that it's Display issue... would you try to change Color scheme from Options > Display tab.just to see if any change happened.
if not try to  do the follow :
1) type CUI at the command line.
2) In the top left window, highlight your workspace.
3) In the top right panel, click "Customize".
4) In the top left panell, click the "+" symbol next to Quick Access Toolbar.
5) Put a checkmark in the box.
6) Click "Apply" and "OK" at the bottom of the CUI palette.
Hope it's help
Imad Habash
in reply to: imadHabash
Thank you for your kind reply. But both methods did not solve the issue.
pendean
Move the QAT to below the Ribbon and see if that helps.
Why don't you sign up for the free 2017 Student version? 2014 doesn't work well in Windows10 http://autode.sk/1IY4C2X
AutoCAD Inside the Factory
