Invisible blocks in the thousands causing issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am currently getting .dwg files from architects that seems to include invisible blocks. These blocks from some architects seem to number in the 16,000's, while the largest mass of them that I have gotten was around 116,386 instances of them.
I have gone through some of them and found the blocks using a QSelect and selecting them by name and then deleting them one by one. Even with nothing else in the drawing, having this block in the drawing causes a stuttering on my machines. (Some of which are spec'd way beyond what a drafter would need)
Today, while dealing with one of these drawings, I decided to peak inside the block. There was oddly another block named "DIMSET" (Going to try to upload a stripped out version of it)
This is interesting, because DIMSET shouldn't be causing this stuttering and there is nothing else in the drawing.
Anyone know how to cause the stuttering to stop? In the attached file the block is called "Setup", but in other files it could be a number of things. Sometimes they reference the architect's local drive.
I have tried to ask the client to get the architects to stop leaving these annoying blocks in, but they seem to refuse. If I mass select them and delete them, the stuttering stops.
What is causing this? Besides having them stripped, how do I fix the stuttering?
