Inventor look and feel
tmccar
Advisor Advisor
tmccar
I use Autocad frequently in 2D and I want to use it for 3D also. I like working in the Inventor environment, with the "Sky" color scheme. Also I like that you can start sketching on any face.
         Could the Autocad environment be set up with a similar look? What color combination would I need?
Also, does Autocad allow sketching on faces, and parametric modelling?
pendean
Community Legend
Community Legend
As they say, if you want to use Inventor, use Inventor. If AutoCAD looked and acted exactly like Inventor, Inventor would not exist Would it.
FWIW your background can be any color you want anytime in AutoCAD https://www.javatpoint.com/autocad-background-color
Wonder what you'd find in you typed the word PARAMETRIC in the HELP box at the top right of the program window... . BUT... do you know there are variants of AutoCAD other than plain-Jane version that may be more appropriate for you to use (and are free with your AutoCAD subscription) like https://www.autodesk.com/products/autocad/included-toolsets/autocad-mechanical
HTH
