Inventor exported .DXF Clean up in Autocad
will_roe
will_roe
Hi!
I'm currently trying to streamline the process in which the office exports DXFs for in house plasma cutting.
We currently export face on our inventor parts and then open it in Autocad and explode, purge, overkill and export as 2007 (our plasma is quite temperamental).
I have Inventor side sorted so it's dropping a .DXF in the users downloads folder and I've written a script and made a button using a Macro via CUI to do the cleaning.
Where it seems to trip up is saving as a 2007 DXF. I've been using DXFOUT which works when I type it out but when I make it a script it seems to trip up saving over itself. Alternatively I tried using .dwg to then export to .dxf and it still won't work. I'm trying to avoid running it with just the default settings because a few other people will be running it and I feel this is a variable I don't want to contend with if I want a 100% success rate in running it.
Here's what I have-
_PURGE
A
N
EXPLODE
ALL
_AI_SELALL
-OVERKILL
D
_AUDIT
Y
_DXFOUT
_VERSION
LT2007
16
Y
Alternatively I tried using just the macro to just get the DXFOUT part to work without success-
^c^c_DXFOUT;^m;V;LT2007;16;Y
I appreciate any help I can get on this one.
Cheers
TheCADnoob
This seems to work for me
_PURGE
A
N
EXPLODE
ALL
_AI_SELALL
-OVERKILL
D
_AUDIT
Y
_DXFOUT
V
LT2007
16
CADnoob
will_roe
Thank you! I can get it to run like it should now if I export it as a .DWG from inventor but then when I open the exported DXF after running the Autocad script it still has 3 layer that can be purged (Hidden, Centre & Phantom) this shouldn't be a problem but this method means the user has to delete a bunch of .DWGs.
I would love to get exporting from DXF to work. The problem I run into with the .DXF (I think) is for some reason when running DXFOUT as a script it doesn't like to replace its own source file. You get the below message. Annoyingly if you finish the script after AUDIT and type out what the script would input there are no issues.
Does anyone have any ideas how to fix this or a work around?
cadffm
The whole file as DXF?
For this, use _.SAVEAS instead _.DXFOUT
For testing and to see the options, set filedia temporary to 0,
start _saveas command..
Sebastian
will_roe
Cheers, that works but for some reason purged linetypes come back when I reopen it. Luckly the plasma cutter seems to tolerate them🤞
Ended up with-
EXPLODE
ALL
_PURGE
A
N
_AI_SELALL
-OVERKILL
D
_AUDIT
Y
_SAVEAS
DXF
V
LT2007
16
Y
TheCADnoob
Excellent. Glad we could help and I hope the plasma cutter stays ok with it haha.
CADnoob
