第 1 条消息(共 3 条)
不适用
04-23-2016
08:07 AM
Hello - We have two solids (Each solid is a 3D Solid entity) and as we try to find the intersection volume we get the following error:
Command:
INTERSECT
Select objects: 1 found
Select objects: 1 found, 2 total
Select objects:
The Boolean operation on solid and/or surface bodies failed.
Modeling Operation Error:
Inconsistent graph vertices.
Command:
Please see the attached file and please note that the intersection volume will represent the actual volume of the earth dam. Any ideas or help is greatly appreciated. Thanks in advance.
已解决! 转到解答。
