Message 1 of 12
Anyone seen this error and have a solution? I get this error when I try to copy an AutoCAD table. It crashes the file.
Yes, I did a web search about the problem. Unfortunately, nothing found pertaining to the @1719 error.
Hi @RocksterB,
Can you attach a sample file with a table in it that causes this error? Which version of AutoCAD are you using?
Have you started with AUDIT and Purge to see if that helps?
I did a purge and audit. AutoCAD reported no problems to be found. I even did a recover drawing. So, I decided to delete the table and recreate it. I really don't like doing this because I still haven't learned exactly what caused the problem and if I truly eliminated the issue. But I am up and off to the races again. What does eWrongDatabase even mean? I'm in version ACAD2015.
How do you "So, I decided to delete the table and recreate it. "?
I'm getting !dbspace.cpp@1743: eWrongDatabase error and recover/audit isn't helping.
My job is due today, of course.
Hi @Anonymous,
Is it possible to share the drawing(s) with me so I can try to help you get this out on time? If they need to be private, send them to me at john.vellek@autodesk.com.
I'll email you 🙂
Its been a few weeks, but I believe my issue was associated with a particular block. I had to create a new block and assign it to the cells. Were you able to resolve your problem?
I'm tryed uncheck Unicode UTF-8 in language & region , it work
