Intermixed font styles within one text block
AIR_123
AIR_123
Please help. This is very weird problem. After restarting a drawing text fonts within several text locations (also inside blocks) are intermixed. Original font is ISOCPEUR. And now it seems its intermixed with Aerial somehow.
StripText lisp did not worked.
imadHabash
can we have a sample CAD drawing please for your issue ? check if  ATTSYNC command can help .
Imad Habash
AIR_123
please find sample file below
imadHabash
i suggest to remove formatting as shown below ( select all of your text then right click ) .
Imad Habash
vinodkl
Not sure how you used the STRIPMTEXT lisp, but it works on this text on my end. You need to have the "Font" checked which would remove the font formatting.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
AIR_123
At first StripText lisp did not worked. After couple ACAD restarts problem disappeared. So problem solved.
