>> which i could not transform into poly line to calculate area
Draw a line (with object snap) to connect the upper two endpoints, same for the lower endpoints.
Then draw a hatch inside the area ... selecting the hatch shows you the area in the property window.
>> by dash lines
I hope you mean "lines with linetype dashed" and not that this is a sum of separate lines with spaces.
If the expected or necessary accuracy you need is not too high:
Start command _PEDIT with option _MULTIPLE, then select these small lines, now option _JOIN and for the fuzzy tolerance use a value a bit higher than the space between these small lines.
This will create a polyline for each of the sides, giving you more options to connect the right and left side, make a closed polygon from that and get the area as result.
Next time please upload the dwg-file so we really know what you have, so no need to guess for us!
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
