HI @Anonymous,
Which version of AutoCAD are you using? If you are on the Mac version, the Ribbon does not exist as the user interface is designed with the macOS in mind.
If you are in a Windows based product you can start by typing the command RIBBON.
Is it possible to do a screen capture so I understand what you are currently seeing on your screen?
John Vellek
