Installation errors
Installation errors
xxxxxx ??? please help me     OTL
That blue write  ---->>>> On an attachment
mpeperkamp
Hi @Anonymous,
May be the following website can help:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Autodesk-program-installation-fails.html
https://forums.autodesk.com/t5/installation-licensing/some-products-fail-to-install-result-1603/td-p/3382347
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Alexander.Rivilis
You can try to use  Autodesk Virtual Agent in order to download and install full installation package of AutoCAD 2017
Instruction:  Installing Autodesk products from the Virtual Agent
It will be English version of AutoCAD. After it installation you can download and install Language Pack: AutoCAD 2017 Language Packs
Facebook | Twitter | LinkedIn
Expert Elite Member
Emmsleys
Hi @Anonymous,
Welcome to the AutoCAD community.
Let's have you try the following:
  1. Perform a Clean Uninstall
  2. Installing Autodesk products from the Virtual Agent
Sarah Emmsley
Technical Support Specialist
