I'm having trouble installing AutoCAD from our typical install point. I've tested and confirm that it works on other systems. On this one computer I keep failing to install. This is the log:
--snip log file--
2015/8/10:15:49:33 user HOSTNAME === Setup started on HOSTNAME by user ===
2015/8/10:15:49:33 user HOSTNAME Path_Length: 155
2015/8/10:15:49:33 user HOSTNAME Current Directory C:\Users\user\AppData\Local\Temp\_AIA7F0.tmp
2015/8/10:15:49:33 user HOSTNAME Launch
2015/8/10:15:49:33 user HOSTNAME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIA7F0.tmp\Setup\AcSetup.dll
2015/8/10:15:49:33 user HOSTNAME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/8/10:15:49:35 user HOSTNAME Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Users\user\Desktop\AutoCAD_2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
--end log file--
From looking at other posts this seems to happen when the installer try to install a pre-requisit and then the whole install fails. I've tried by removing all MS Visual C++ packages installed and the app still fails.
If I use the GUI mode I have another error where the installer fails trying to find a directory named something like Autocad\R19.1 and then will not go any farther.
I've attempted to add the registry key under "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders" for Common Documents as no keys are in this location as it looks like Windows 7 Pro uses a different location. This did not fix the installer.
I'm at a lose to what I can attempt next.
Any help appreciated
