Install AutoCAD 2025 - "Problem loading AcBrandRes.dll resource file."
kejunwu2-c
Observer Observer
kejunwu2-c
Observer
Observer
Hi all,
I encountered a problem running AutoCAD 2025. After I installed it and tried to run it, a pop-up window appeared with the prompt: "Problem loading AcBrandRes.dll resource file." I re-downloaded and installed it several times, but the same problem remained.
Thanks so much for your attention and assistance!
Rose
paullimapa
vinodkl
Hello @kejunwu2-c
Please perform a clean uninstall to fix this issue. Here is how you can clean uninstall: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall-of...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
apbrc23008_meemansa
Community Visitor
Community Visitor
Does using a student id free trial hinder this mentioned solution?
paullimapa
Nope so give those solutions a try
Paul Li
IT Specialist
@The Office
