I use a variety of scales for assemblies. I use the "Table" command to insert a table that references an excel file.
Is there a way to have the table annotative?
I want to be able to have the text height to be consistent with the dimensions and other text.
I currently insert my table and scale up the table. Then when the table is updated with additional rows, the new text maintains the original text height, and requires editing.
I have also deleted the table and re-inserted it. Then scale it again.
Solved by john.vellek. Go to Solution.
Hi @jploughman,
If you are adding data that is contained in the drawing file(s) have you considered doing a DATAEXTRACTION and writing the results to an Excel file? Then, using a Datalink, you can add a table.
I am not aware of any way to make a table annotative (maybe in a block?) but I usually place mine in a paperspace layout so I have never needed to change the scale.
If you like to attach some sample files to a post I am happy to investigate further.
Hi @jploughman,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post solves your issue or answers your question.
