Inserting X-Ref using the BIND command won't insert the entire X-Ref
reisalex341
reisalex341
When I try to insert an X-Ref into a drawing it won't put the drawing in and only puts a 2D portion of the 3D drawing. The insert option worked for other parts of my drawing but wont work for others. The xref was made in AutoCAD and I'm not sure why it will not insert.
 (After Inserting)
 (Before Inserting)
pendean
Community Legend
Community Legend
Perhaps your top file has the same layer names and those are frozen/off by chance?
reisalex341
All my layers are thawed and turned on.
pendean
Community Legend
Community Legend
Can you share DWG files?
paullimapa
when you post insert do you mean xref attach?
Paul Li
IT Specialist
@The Office
Valentin_CAD
@reisalex341 ,
If you have not already, try the suggestions from this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
reisalex341
The reason was the blocks within the drawings were defined differently, thanks for the help.
