Inserting multiple blocks
lbellino4
lbellino4
Hello.
Does AutoCAD have an option to insert multiple blocks all at once and updates/redefines those that are in the drawing, if any of the blocks have been updated?  I'm working in a drawing where it has blocks that I know have been updated and I would like to update all at once vs. one at a time with the standard "insert" function. Is this possible? Thanks in advance.
Working in ACAD 2022 version.
cadffm
I believe there is just one hidden and undocumented(?) way for the case that all blockdefinition are internal blocks of one file.
(If you have single DWGs which you insert "as Block", you need tool or simple script)
Toolpalette or Designcenter, I guess it is the Toolpalette:
Drag&drop the  myblocks.dwg to the palette, insert one blockreference to your target file, right click on the new  insertion tool , REDEFINE
Done
Does it works? I am away from ACAD and can't test for you.
Sebastian
pendean
Community Legend
Community Legend
tramber
IF you got a list of the updated blocks, I beleive that nothing than a simple script that you can run when needed should do the job.
But it would need that the blocks are in a research path.
I am not sure and ain't got the time to verify but it seems to me that we can use -INSERT for an inline solution with the "=" key
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-BB831F94-6385-4490-8DE9-7C565CD1B639
If you succeed in updating one this way, then, you may do it massively with a script that you can maintain in your org.
As you may find lisps, I don't go far and try to remember if I ever tried, once 😁
