inserting blocks by using values in excel sheet
ebru_kilinc
Message 1 of 23
ebru_kilinc
I am searching a method to insert blocks by using excel sheet which contains coordinate and rotation information. My blocks have rotation, x and y attributes. I would like to insert my blocks with correct coordinate and rotation by using my excel sheet. I managed to insert the blocks with several steps but only with the correct x and y values. I can't rotate the blocks by using the rotation value in the excel sheet. do you have any suggestions/ lisps to do the trick?
Replies (22)
Message 21 of 23
ВeekeeCZ
Open one block of that name in the block editor and close it with save.
Message 22 of 23
Mike_Y2
Is there a way to use you method to place a dynamic block with the attributes, properties / parameters as per the attached pic's?
Message 23 of 23
Amriya_Exe
Please upload block also.
