Inserting blocks at scale
whitney_jeff
Message 1 of 13
whitney_jeff
I have a dynamic block, sheet title, consisting of a line, several attributes and a circle.  In the sheet title block itself, everything is the correct size for 1:1  paper space, and also in the block editor.
When I insert it in a drawing in paper space, scale factor 1, it shows up at about 12 times too big.  Both files have insertion units set at inches.  INSUNITS set at 0 or 1 makes no difference.
Any ideas?
Replies (12)
Message 2 of 13
imadHabash
i suggest to check if your block is Annotative object. annotative object will behave different if the annotation scale ( status bar) are not 1/1 and it will follow the current scale.
Regards.
Imad Habash
Message 3 of 13
user181
Is the block you are inserting into paper space a block that is within the same drawing or is it a separate drawing that you are inserting?
Message 4 of 13
whitney_jeff
Thanks, it is not annotative.
Message 5 of 13
whitney_jeff
separate drawing - dragging and dropping.
Block attached - bear in mind please that I did not create this block Smiley Surprised
Included the block and a drawing it was inserted into (no xrefs included)
Thanks for looking!
Message 6 of 13
Darin.Green
@whitney_jeff
Copy (or WLOCK) the contents of the TITLE-SHEET to a new file then it'll work fine. You have a bad Drawing File...
Note, each item within model space has a duplicate on top of each other.
DO NOT USE THE SELECT ALL TOOL ->> Because there's more items in a background of the file also duplicate geometry...
If this information was helpful, please consider using the Accept Solution
Message 7 of 13
whitney_jeff
Thank you so much Darin!
Works perfectly now!
Jeff
Message 8 of 13
shannonbH2WBX
I am having this issue as we are switching to 2020.
My setup is working fine, but a coworker inserts a border mask and everthing is x12.
I have checked his Units, gone to Options-User Preferences and all his settings are the same as mine.  These blocks all worked correctly before the change over.  What are we missing?
Message 9 of 13
shannonbH2WBX
Anyone?
Message 10 of 13
whitney_jeff
You have checked insunits?
Message 11 of 13
shannonbH2WBX
Yep, and all the above.  I thought maybe it was something new with 2020.
Message 12 of 13
whitney_jeff
As was suggested to me on the same topic, try wblocking the drawing from your computer/workstation.
If possible, use the * option (-wblock name *) where name is either a new name or the name of the current drawing.  If you use the current drawing name and location answer yes, you want to overwrite.
HTH
Jeff
Message 13 of 13
shannonbH2WBX
It must be a setting on his Autocad setup.  If I open his dwg it works fine when I insert the block, I'm stymied, I've checked every setting mentioned here.
