Inserting a JPEG into a DWG + issue with Hardware acceleration
Message 1 of 13
I have a 2 month old HP Z Book with 2017 AUTOCAD. Recently I am unable to use INSERT and ATTACH command to insert JPEGS into drawings. I tried OLE command, but pics were squashed!!
THEN - Suddenly my dwg. colors are all different. Red to Blue, Yellow to Cyan. I used GRAPHICSCONFIG command and turned off Hardware Acceleration and it fixes the problem, but WHY did this happen? Does it mean there is a problem with my graphics card on brand new computer??
Does anyone else have this problem? ANY help is much appreciated.
MaureenC
Replies (12)
Message 2 of 13
Alfred.NESWADBA
Your AutoCAD is not up-to-date or your graphic card driver is defect (may be not up-to-date too).
Please start AutoCAD, start command _ABOUT and upload a screenshot from that dialog.
Same with command _GRAPHICSCONFIG
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 13
[image: Inline image 1][image: Inline image 2]
Thank you Alfred - here are the 2 screen shots.
Message 4 of 13
Alfred.NESWADBA
sorry, no images attached here.
Please don't answer using your mail system as that does not forward attachments, please use the reply option in the forum thread/post instead, there you can add files to the post.
- alfred -
Alfred NESWADBA
Message 5 of 13
Ok, trying this. I cannot seem to do a screen shot here. So I am attaching photos of the screen for those 2 commands.
Message 6 of 13
Alfred.NESWADBA
thank you for your screenshots!
Version O.49.0.0 means you don't have any service pack installed for your AutoCAD 2018, so please start Autodesk Desktop App, make sure you are logged in and wait a few minutes until the list of updates is refreshed ... then install these updates.
If that is done try again the same function and let us know the results.
- alfred -
Alfred NESWADBA
Message 7 of 13
Hi Alfred,
Good news!! I installed updates and NOW able to leave Hardware Acceleration on and colors are all good!!! The ABOUT command still says Version O.49.0.0 tho.... why is that?
My other issue is still not working. See attached screen shot after I click on INSERT then ATTACH.
Thank you SO MUCH for your help!!!!
MaureenC
Message 8 of 13
Alfred.NESWADBA
Reboot your workstation, then start AutoCAD, if it again says O.49.0.0 then I guess the update either failed to install or did not install.
Sorry, the screenshot does not show me what the error is.
- alfred -
Alfred NESWADBA
Message 9 of 13
Hi!
I rebooted and the version does not update, stays at O.49.0.0. AND, colors not working again. SOOO.. Yes, the updates are not installing properly or at all and presently my Autodesk Desktop App says I have no new updates to install.  Earlier - when the colors worked correcly for a brief time - the GraphicsConfig message stated that my graphics card was an Intel 620. Now when it is not working - it says the graphics card is an AMD FirePro. Actually this computer has both.
Re: other issue. The error is that a message comes up that says "Path to file to attach" - but does not allow me to open an file to attach.
Thanks for your help!!! SADLY... I think my problem is the graphics card?? And I must go back to HP???
Message 10 of 13
Alfred.NESWADBA
Are you logged in? Login is necessary so the Autodesk Desktop App knows which products you could have and also to get the information about subscription and so possible updates to install.
Then update the AMD drivers for your graphic card.
Please again, create a screenshot from that messagebox (please find >>>here<<< how you can create screenshots on your computer).
- alfred -
Alfred NESWADBA
Message 11 of 13
KUDOS for telling me about the Snipping Tool!! Attached is screen shot.
I WAS logged in on Autodesk Desktop App. I will try to update the AMD card. :(. Thx.
Message 12 of 13
Alfred.NESWADBA
well, I now see that the filename is requested in the command-line instead by an file-open dialog. Therefor please set the sysvar
FILEDIA
to 1
For the update: you can login to your subscription center (http://manage.autodesk.com) ==> AutoCAD ==> 2018 ==> updates and download the update from that location, then install it manually.
- alfred -
Alfred NESWADBA
Message 13 of 13
Hi Alfred,
KUDOS, KUDOS, KUDOS!!!  File open vs. File name.... I get it! Thank you! its working now!!! I am so happy!
Now as far as my graphics card. I will try to update via the Autodesk Desktop App - I was thinking its a hardware issue and I have to go to HP cuz it came with the computer, BUT I will try the Desktop App and let you know.
AGAIN!! THANKS!!
MaureenC
