Insert block on layer 0
Hello everybody,
before a big discussion is started - I know how layer "0" and blocks do work together. But I was wondering if it is important to insert blocks on a specific layer (if the objects inside the block are not on layer "0"), maybe layer "blocks" or if I could leave them on layer "0". Is there anything for or against it?
The only thing I noticed is, that if I have a block called "screw", which contains all objects on layer "0" (except center line) which I could insert on layer "visible" or "hidden", I can not select this block while I am picking all other blocks which are inserted on a different layer. It is a bit hard to describe...
