Hi, I'm fairly new to visual lisp editor and I'm testing out a simple code that finds an area of a closed polygon, creates a block attribute and inserts it with the new value:
(defun c:P_blocks(/ s a sqft area) (setq s (car (entsel))) (setq s (vlax-ename->vla-object s)) (setq a (vla-get-area s)) (setq sqft (/ a 144)) (entmake '((0 . "block") (2 . "room") (10 0.0 0.0 0.0) (70 . 2) )) (entmake '((0 . "ATTDEF") (1 . "area");value (2 . "room");Tag string (cannot contain spaces) (3 . "square footage ??");Prompt string (8 . "wall");layer (10 0.3 4.3 0.0 ) ;First alignment point (40 . 2.0); (41 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (72 . 0) (73 . 2)) ) (entmake '((0 . "endblk"))) (entmake (list '(0 . ".-insert") '(8 . "wall") '(2 . "room") '(10 0.0 0.0 0.0) (cons 1 (rtos sqft 2 2)) '(41 . 1) '(42 . 1) '(50 . 0.0) )) )
every line leading up to the "insert" routine works as follows, but when i run it, i get:
Redefining block "room"
*Cancel*
nil
Any Ideas would be much appreciated.
Solved by Kent1Cooper. Go to Solution.
Wish I could help but I'm not any good with lisp.
You might have better luck if you posted in the lisp forum though.
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
@Anonymous wrote:
.... (entmake (list '(0 . ".-insert") .... (cons 1 (rtos sqft 2 2)) ........
I rarely deal with (entmake), but I see a couple of things....
The period and hyphen preceding the word insert may be appropriate with a command name, but are not appropriate in an entity type name. Try it just the way it appears if you (entget) a Block insertion:
'(0 . "INSERT")
The value of the text content of an Attribute is not an element of the Block insertion's entity data -- the Attribute is a separate entity. [After all, a Block can have more than one Attribute, so to which of them would it assign that value?] I'm not sure exactly how to handle that in (entmake), but I would just use (command "_.insert" ... and feed in the Attribute's text content at the end after the scale and rotation entries. [That would also eliminate the issue in my first comment.]
this is true, I was successful in just simply using (command ".-insert" ... sqft) I was just curious to see if it was possible to create the same result in (entmake). Thank you for the insight!
