input from a text file
I need to draw circles with different centre coordinates and different diameters/radiuses. These parameters are calculated in a spreadsheet and saved as a text file. Is there a CAD software that could read this file and draw the circles ? DesignCAD can read a text file (XYZ extension ), but can draw lines only (with start (x1,y1) and end point (x2,y2)).
Thank you for reading this, cheers,
Sek
Patchy
Of course.
Write a script (text file with extension .scr)
Example:
Then use the command SCRIPT to import it.
thanks, much appreciated !
