AutoCAD Forum
Inconsistent UI Scaling
3 REPLIES 3
Test.1.01.cer.2002
254 Views, 3 Replies
My UI has inconsistent scaling (see attached photo): most parts such as the ribbon and menus are fine, but other parts such as the WCS tool and the display drawing grid are too small. Then the command line is obnoxiously large...
Some useful info:
- I have this same version of AutoCAD installed in another computer and never had these issues
- The computer giving me issues has a 4k monitor
- My system display scaling in windows is at 200%
Things I've already tried:
- Changing UI scaling to 100% in windows - This makes scaling consistent in CAD, but the UI is far too small and basically unusable.
- I tried enabling "Override High DPI Scaling Behavior" in the program properties
- I do not se anywhere to adjust UI scaling within the program itself?
3 REPLIES 3
Hi @Test.1.01.cer.2002
See if this article helps:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gr...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Thank you for your response. I installed the hotfix but nothing changed. What else could be the problem?
Hi Charles,
Autodesk is definitely making strides dealing with 4K Monitors, but they're not there yet. I know you said you enabled Override High DPI Scaling Behavior, but did you try selecting either "System" or "System (Enhanced)"? That usually fixes it for me.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
AutoCAD Inside the Factory
