Importing coordinate points with annotations
rohanQREWS
rohanQREWS
Is it possible to import point coordinates from an excel spreadsheet in a way where the point in CAD will have annotating information attached?
I have tried using the CONCATENATE function in excel to combine the coordinate data and then just pasting into CAD using multiple points. However, this just puts the points themselves in at the coordinates without any of the other data.
The aim is to create an easy-to-read plot of soil test locations with the soil samples identification number, test depth and test result displayed. I have previously done this manually which looks like this:
With the excel data set out like this:
Is there a way to achieve this outcome using AutoCAD, preferably without the use of third-party software if possible?
rohanQREWS
Hey guys, can't see where to mark this as solved but I found what I was looking for in this thread: Solved: Re: Import point number and xyz data from excel and display # - Autodesk Community - AutoCAD
