Hi, il keep it simple. does anybody know of a way to import a LAS point cloud file into Autocad. Without using any other software.
Solved by dgorsman. Go to Solution.
Solved by pendean. Go to Solution.
@pendean wrote:
MAP or C3D can I believe, in plain AutoCAD I think you already know this http://www.teledyne-pds.com/faq-2/can-we-import-point-cloud-data-in-autocad/
I think the latest round of releases is now limited to ReCap files. Since ReCap is included with almost all products it shouldn't be an issue (aside from not meeting the strict requirements of "no other programs"), and the ReCap point clouds have better performance in host programs.
Cheers, the workflow seems fairly simple with recap and the Autocad functions are greatly improved with a recap native file. Cheers
