Importing a DGN Not Working
cpaarmann
Message 1 of 10
cpaarmann
Hello, my company has switched from Microstation to AutoCAD and I have some old .dgn files that I'm having trouble opening in AutoCAD. When I try to import the .dgn file it imports the following text block. I am unsure what it means by "SWITCH YOUR MODEL TO THE APPROPRIATE BORDER SIZE" and AutoCAD's help menu has yielded no results. Any suggestions?
Replies (9)
Message 2 of 10
imadHabash
If you start a new dwg file .. any changes ? OR you may need to check the DGN version .
Imad Habash
Message 3 of 10
cpaarmann
I started from a new dwg file, no changes. Unfortunately I can't open the dgn version since I no longer have access to Microstation. Any other suggestions?
Message 4 of 10
pendean
Community Legend
Community Legend
Can you share one of thee DGN files for review by other here?
Message 5 of 10
cpaarmann
The attachments function will not allow me to attach dgn files. Is there a different way I can share?
Message 6 of 10
pendean
Community Legend
Community Legend
You can ZIP then file then post it here by coming to the site to post it, or you can use your DROPBOX or OneDrive or GoogleDrive or other cloud service to share files too.
Message 7 of 10
cpaarmann
Thanks, please see attached zip file.
Message 8 of 10
pendean
Community Legend
Community Legend
Thanks for the file: I had no issues at all with DGNIMPORT in AutoCAD 2021.1.1 once I completed the import pop-up settings based on my expectations. See attached.
Message 9 of 10
cpaarmann
What import popup settings did you use? Perhaps I'm not setting those correctly.
Message 10 of 10
pendean
Community Legend
Community Legend
