Importance of hardware requirements
Greetings. I support several clients with AutoCad and personally seem see a correlation between the number of support calls I get from clients that stick hard and fast to your hardware requirements on their system builds and the ones that don't. Specifically when it comes to Windows 10 version upgrades.
I have not had any of my clients that are using required hardware have problems when a new version of Windows 10 comes out but clients that have non-listed video cards, motherboards, etc seem to have various unusual issues each time Windows Comes out with a new version update.
My question is if my observations are isolated to my clients or does the hardware requirements make that much difference in your testing of OS versioning?
Thanks in advance.
chriscowgill7373
I'm not sure if your question is directed at Autodesk or just a generalized request for a response.  in my experience, having certified video cards help, as for any other hardware, and even having non certified cards does not make the product unusable.   the only factor I consider with the machines we order now days is the video card, previously, we built our machines with whatever seemed to work well, and was not tied to anything Autodesk tested or certified.  so to answer your question, in response to the machines and hardware we have and windows updates I have seen no difference in compatibility with Windows updates,  all of our systems continue to function, whether using uncertified hardware or not.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
These types of issues can be expected and is not specific to this specific set of your clients.
Here is a link to frequently asked questions regarding certified hardware.
Compared to standard Windows software, AutoCAD works more directly with computer hardware like graphics card and printer drivers.  So it is not surprising that changes in Windows OS updates will more likely impact AutoCAD that is running on systems that do not meet the AutoCAD hardware requirements.
Getting the most up-to-date drivers from the graphics-card or printer company is going to be the first suggestion. And for graphics-specific issues, running the GRAPHICSCONFIG command and disabling line smoothing and high-quality geometry may help users with older graphics-cards by not taxing the card GPU
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
