Import Word document into AutoCAD
Dear Sir/Madam
I want to ask you something about impmort text because i have aproblem.I want to bring a word document in my drawing.I press the button ice_screenshot_20160510-155412.pngafter i see this windowice_screenshot_20160510-160420.pngi chooseice_screenshot_20160510-160149.pngand isee the same pictureice_screenshot_20160510-160420.png(screnshot4)with other words in the partucular window there are not my word documents that there are in my desktop .You can see that there 3 different documents in my computer (in the screenshot 5) and there are not in the window (screenshot 4) with resault i can not make text import.
where is the problem and i how i can fix it?
@Anonymous,
john.vellek has edited your subject line for clarity: import text
john.vellek
Hello @Anonymous,
It appears that you are selecting RTF format files. This is Rich Text Format. Word can save in this format if you choose but will not show up in your dialog windows unless you save as this format with the RTF file name extension.
You can also copy paste Word docs into AutoCAD and also straight into the Mtext editor. (This is my preferred method)
Start your MText editor, then copy /paste from Word or use the Import text function.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
DGRL
@john.vellek
May I ask you how you copy and paste WORD documents into AutoCAD?
I just tried and I miss the footer and header
All I see is incomplete word into autocad
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Alfred.NESWADBA
Hi, please don't >>>crosspost<<< (double work for you and for us too), - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
DGRL
@Alfred.NESWADBA
I am not cross posting as I have a different question
Just need to remove my question up here.
You could better say
Don't go off topic  :wink
Kind Regards
