@Antonin_JubaultSRF25 ,
...Given this file:
{ "block_name" : "block1"},
{ "block_name" : "block2"},
{ "block_name" : "block3"}
...This code:
;; Hastily parses JSON to Lisp
;; json - string, as json data
;; returns - list or nil, list of data converted from json
(defun ParseJSON (json / )
(if (eq 'STR (type json))
(read (vl-string-translate "[]{}:," "()() " json))
);if
);defun
;; Reads file at provided path
;; filePath - string, full path & name of file to read
;; returns - string, of file contents (newlines not preserved)
(defun ReadFile (filePath / f line contents)
(if (setq filePath (findfile filePath))
(progn
(setq f (open filePath "r"))
(while (setq line (read-line f))
(setq contents (cons line contents))
);while
(close f)
(apply 'strcat (reverse contents))
);progn
;else
;; File not found
);if
);defun
(defun c:MYBLOCKS ( / filePath json data blockName)
(setq filePath "c:\\users\\me\\test.json")
(if (and (setq json (ReadFile filePath))
(setq data (ParseJSON json)))
(progn
(foreach item data
;;;(prompt "\nHere is full item: ") (print item)
(setq blockName (cadr item)) ;;<-- this should retrieve "block1", "block2", etc..
(prompt (strcat "\nBlock Name: " blockName))
);foreach
(prompt "\nMYBLOCKS Complete.")
);progn
;else
(prompt "\nUnable to find file OR parse Json.")
);if
(princ)
);defun
...Will return this:
Command: MYBLOCKS
Block Name: block1
Block Name: block2
Block Name: block3
MYBLOCKS Complete.
...As far as "inserting" the blocks, that will be on you because I have no idea where these blocks are located lol.
Best,
~DD
