imperial drawing with wrong areas
Message 1 of 9
i received a dwg file from a client that looks like it was taken/converted from a layout(sheet) to a modelCapture.PNG
i have to use areas in this drawing to do some mechanical calculations
being a person who is more familiar with metric system, whenever i receive such a thing i scale the whole thing by 25.4 and get areas in mm
if you look below, the dimension in magenta is just linear dimension command on his raw file that shows something different. also the room area shows 1.5 square inch which is 100% wrong.
the client is not a CAD expert and claims his drawing is correct. and im sure this drawing is having a scaling factor that completely messes up all dimensions/areas but i cant find out what exactly.
can anyone help me here ?
Replies (8)
Message 2 of 9
imadHabash
you may need changing your dimension style and other things >> Click <<    >> Click <<  .
Imad Habash
Message 3 of 9
thanks for your input and useful links
but if you notice i applied the linear command to his raw file and even his imperial dimensions/areas are wrong so i guess that indicates the file itself is being scaled....somehow
Message 4 of 9
imadHabash
would you attache here just a small part from your CAD file ( before scaling ) please , for testing ? make it as AutoCAD 2013 file format ( save type ) .
Imad Habash
Message 5 of 9
thanks again, mate
sure here is a portion of the file
Message 6 of 9
imadHabash
after opening your CAD file , i think it's NOT an accurate drawing and not follow any unit value . for that i suggest to do :
  • from DDUNITS command change Length type and insertion scale for your needed values .
  • select a trusted existing dimension distance and draw a line from it that represent your metric new distance like ( 9' inch = 228.6 mm ) .
  • Now scale all of your drawing by SCALE ( Reference ) to that new line in mm , to find now that you have a good trusted drawing . >> Click <<
Hope it's work fine ... 🙂
Imad Habash
Message 7 of 9
thanks for your help
but the issue is that i don't trust a single dimension drawn in this file. it seems like its all messed
client claims these bedrooms are 30sqm and when i scale the drawing it shows its only 6.2sqm lol
also i tried the solution you mentioned but doesn't work
Message 8 of 9
pendean
Community Legend
Community Legend
As noted by others about your DWG file:
"...it's NOT an accurate drawing and not follow any unit value..."
You and your file creator need to talk with and to each other: you were sent a scaled drawing with an unknown scale, this file is useless unless you want to own (aka take liability for) the results from fixing it with ALIGN command's scale option since the DWG is littered with clear (yet fudged) dimensions.
I'm finding it hard to determine what DIMLFAC setting they used to create those dimensions myself.
Once you get an accurate 1:1 scale DWG file you can XREF it into one of your metric template files to do take-offs in metric if you need to do that.
Message 9 of 9
by the looks of the layout and dimensions, im thinking it is a converted PDF file since no dimensions make any sense on the drawing.
also i dont even know how to fix this file in the first place tbh.
