- Mute
- Permalink
- Report
Hello! Im no expert when it comes to using autoCAD and I may seem like an obvious solution, but im having trouble when it comes to attaching an image to autoCAD. I set the scale to 1:1 but when it comes to measuring distance it changes depending on if the exact same image attached is bigger or smaller. I used this program a few months back and it was working fine and I havent done anything different, but something changed and I dont know what it is. For example i link an image and the distance is 0,19 mm and i attach the exact same image but a little bigger and the distance changes to 312 mm (example of how different the measurments are) when it was working for me just fine before. I hope somebody knows why this is happening to me. Thank you in advance!
