Copy and paste is not working in a super weird way
yauming1023
Message 1 of 12
yauming1023
Issue started so suddenly, everthing worked fine until a point that the pasteclip does not paste stuff anymore.
- When I use Crtl+C / Ctrl+V, or copy base or any other copy methods (not including the usual "copy" command, that works fine), stuff I copied, even just a simple line, it does not let me paste. After hitting Ctrl+V or pasteclip or whatever just nothing shows up, no errors no popups, only showing "specify insertion point" in command line but it is totally blank next to my arrow.
- I first thought it only happens when I copy somthing from one drawing to another, or maybe it is some scale setting mistakes between drawigns but actually, I cannot even paste right next to the stuff I just copied. Also it takes a very long time to copy even just one line. This issue only happens in few files that I recently working on, some other files are fine.
- I have already tried: insert the whole dwg instead of copypaste (but it won't even let me insert neither, it is inserting blank), WBlock, Purge, -Purge regApp, Audit, Copy whole dwg to a new file, setting Pickfirst to 1, or any other solution that could be found on google, none of them worked. The weirdest part is that when I purge/audit the file, I save and close and reopen, sometime it will let me copy and paste normally (still taking unusual time to copy), but after pasting whatever I just copied for 2-3 times, it appears pasting blank again. It feels like it's saying "hey you used your only shots, nope".
This is so wierd I really hope someone can help me fix this. Thank you.
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Dumb question if I may: have you restarted your PC yet? Not in your list of "... I have already tried...".
ASSUMING... when you expand your commandline to be 5-10-20 lines tall and try again there is no error or alert message being reported about the content being copied of course (and if there is, what does it say?).
Screenshots of your ABOUT command and your OS details would need to come next if you are still facing issues.
Message 3 of 12
ChicagoLooper
Hi @yauming1023
After you've copied to clipboard and before you've pasted, look at command line. Verify whether you have any objects on your clipboard. The copy-and-paste function only works is you've properly copied objects and such objects are copy friendly.
Chicagolooper
Message 4 of 12
paullimapa
This happened in the office I last worked at awhile back when we received drawings that had the "china" virus.
There was an acad.lsp that would be present in the same folder as the dwg itself so every time that dwg opened the virus would spread.
We had to eliminate all occurrences of acad.lsp and use the free Drawing Purge tool on all drawings to resolve the copy+paste problem.
Paul Li
IT Specialist
@The Office
Message 5 of 12
leeminardi
Make sure the visualstyle is "2D Wireframe" and try again.
lee.minardi
Message 6 of 12
yauming1023
@pendean  @ChicagoLooper Thank you for replying me.
This is my command line after I copied one line, a rectangle actually.
After typing the (entdel(handent "B")) it just returned like this:
Message 7 of 12
thisispreston
That error is a sign of some kind of data corruption in the drawing.
Have you tried doing a RECOVER on it?
If that doesn't work, then this solution is typically for it happening after a QSAVE but most likely still worth a try as it's the same problem you're having, you're just having it with a COPY command rather than QSAVE.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-Warning-Mult...
EDIT: Sorry, I totally missed the last part of your post saying you had tried the (entdel(handent....
"music is my religion" - Jimi Hendrix
Message 8 of 12
yauming1023
Yes I already tried that (entdel(handent "blablabla")) trick and it returned "error: bad argument type: lentityp nil".
Message 9 of 12
thisispreston
I only ask because you haven't specifically mentioned it, but you tried just a normal RECOVER on the drawing?
If so, then I don't know what else to suggest. I'm not sure what that "lentityp nil" error really means, I'm afraid you're going to need someone cleverer than me to solve this one!
Message 10 of 12
cadffm
>>"that "lentityp nil" error really means"
It means: There is no object with handle"B" (in this momemt).
I could check&explain and perhaps fix it, but I am in holiday.
@yauming1023 should share the file, so others can do it.
Sebastian
Message 11 of 12
yauming1023
@cadffm Thank you for replying me even you are on your holiday.
But I don't think I can share file here cuz it is my company's file.
Would be glad if you have any further suggestions after coming back from holiday.
Thanks everyone here!! this really affecting my work.
Message 12 of 12
pendean
Community Legend
Community Legend
@yauming1023 wrote:
...But I don't think I can share file here cuz it is my company's file....
Not sure anyone here can help you then, sorry.
Engage your company's IT folks to find out what changed with your system and files and perhaps restore them, have them help you clean up all of your DWG files using this very long list HERE, remove/reinstall your software perhaps, AND open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
Best wishes.
