Image in XRef title block doesn't rotate
McCannBQ7ML
McCannBQ7ML
Solved, sort of. See below
In our SD package, most of the sheets are portrait, but a few are landscape. We are using the same titleblock file for all sheets. When the title block xref is rotated 90 degrees for the landscape sheets the embedded client logo image stays in portrait orientation. Why is this happening?
I removed the embedded image and inserted the logo through the raster tools tab. Stays rotated.
nrz13
Would you share a sample drawing along with a sample xref and image that exhibits your issue?  At the very least, I think you will need to share detailed screenshots so we can see what the problem is.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
McCannBQ7ML
I removed the embedded image and inserted it again through the raster tools tab. Works fine now.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @McCannBQ7ML,
Thank you for posting your question. Images can be placed in AutoCAD by either attaching (Xref) or embedding (OLE).
Attached images behave as geometry, and the orientation will change with the other objects in the drawing.
Embedded images hold their orientation in relation to the UCS. See the following Autodesk Knowledge Network (AKN) article for more information:
Many customer resolve this by creating separate landscape and portrait versions of their title blocks.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
